C2 L79 Intake - NCRS Discussion Boards
C2 L79 Intake
  • Mike Swanson
    C2 L79 Intake
    I have just gotten a replacement 3890490 intake for my L79. I have not removed the old on but on the replacement, I noticed a metal plate on the drivers side. From what I can see of the old one that is still installed, it does not have this plate. Doe this look familiar to anyone based on the picture here?
    Thanks as usual for everyone's help.
    Mike
  • Mike Swanson
    Re: C2 L79 Intake
    I guess the picture didn't come through. You can access it at http://www.snapfish.com/viewsharedph...=SYE/otsi=SPIC
    • Mike McKown
      Re: C2 L79 Intake
      I looks like a restrictor that comes in gasket sets for the heat crossover passage under the carb. I believe these things first appeared about '70-'71. Your car didn't originally have one.
      • Paul L.
        • November 1, 2002
        • 1414
        Re: C2 L79 Intake
        Looks like a remnant from a FelPro-like heat passage block plate that comes with the intake gasket set.
        • Scott Marzahl
          Re: C2 L79 Intake
          YOu'll actually want to block these heat passages off with a blanking plate instead of a restrictor to prevent damage warping of the holley baseplate. Several postings of this in the archives by Clem.
