1969 flywheel - NCRS Discussion Boards
1969 flywheel
  • Ben Herbrandson
    1969 flywheel
    Does anybody know the correct flywheel casting number for a 1969 350/350 with an m21 trasmission. Any help would be greatly appreciated. If a site has all the correct casting numbers, that would also be helpful.
  • Dick W.
    • 10483
    Re: 1969 flywheel
    The part # should be 3991469. This had numberous applications for 4 speed small blocks through 1977.
    Dick Whittington
      • 43221
      Re: 1969 flywheel
      Dick and Ben----
      The 3991469 is the CURRENT PART number for the flywheel applicable to the 1969 L-46 Corvette. The original PART number was GM #3889694. GM #3789733 was ONE of the casting numbers for the GM #3889694 flywheel. It, or other casting numbers, may be used on the GM #3991469 flywheel.
