C1 Air Cleaner Wing Nut - NCRS Discussion Boards
  • Gene B.
    • May 31, 1990
    • 144
    Does anyone have a picture of a correct wing nut? I assume the single carb and dual quad are the same.
    Thanks Gene
  • richard geiger
    Re: C1 Air Cleaner Wing Nut
    61 dual quad has 2 long bolts - bolt heads probably 7/16 ( I can look at mine if you need me to) base of the the bolt head is flared out.
    • Gene B.
      • May 31, 1990
      • 144
      Thanks for the response. but I am looking for the wing nut that holds the air cleaner to the carb. Specifically for a 1958.
      • Chris H.
        • April 30, 1990
        • 817
        Gene I asked the same question for my 62 awhile ago. There was no very positive response. See the link below.
        If you want my picture that may not be visible, let me know your email
        Chris
        • Christopher R.
          • March 31, 1975
          • 1599
          Research the sold items at EBay. I believe one of these just sold for a large sum of money.
          • Gene B.
            • May 31, 1990
            • 144
            Chris, I looked at the pictures of the wing nuts. Thanks. Great Pictures. I do have what I thought was the original wing nuts, but I have heard so much from people about them and no one seemed to know for sure what was correct. The one in the middle is about the same as mine. I think the wings on mine are a little bit different, but that is from a 58. They are shorter, but not as short as the Paragon Repro.
            BTW what is a large sum of money?
