C 1 firewall grommet - NCRS Discussion Boards
  • Debra P.
    • September 30, 2004
    • 147
    Hi Boys & Girls,
    I'm almost done getting Blu all spiffy. I found on the fire wall a 1 inch hole with felt like materal. It is for a car with a clutch, I have a power glide. Does anyone know what type of grommet is supposed to go in that hole, & where can I find one ? My car is a 58. I can also use a couple of rubber grommets for under the dash on the passenger side near the heater.
    Deb
  • Mark Malone
    Re: C 1 firewall grommet
    Debra,
    The clutch rod hole is about 2 1/2" below the ledge below the master cylinder.
    I have a pic so if you need it e-mail me.
    If this is the hole it could be blocked by any generic rubber grommet but if you want to use the original style grommets thay are available from most of the bigger outlets such as Corvette Central, Mary Jo etc.
    I would suggest that a generic one will suffice and they could also be used for the others as well.
    Mark.
    My Vette Page
