What is the vertical error allowed for the front end of frame reletive to the rear. Trying to determin what amount of twist in a frame is to much. I am using the difference between all given points and find some futher out than I expected, most are within 3/16 from the stated but I found two in the front end that are 3/8 out on one side of the frame starting with #1 body mount going forward. I am having someone else double check my findings.Thanks to all that respond.
Carl
					Carl
