battery shut off switch - NCRS Discussion Boards
  • nancy charles
    when using a green twist off top battery switch is there a preference to which side of the battery the switch is connected ? THANKS N.C.R.S. member
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: battery shut off switch
    Nancy,
    I use one of those and although some prefer the lever type I personally haven't had any problems after five years use, knock on wood. The one I have would only fit the negative post as the post sizes are different. That would be the one to use anyway on a negative ground system.
    Wayne
      Install it on the negative post - that completely removes all ground potential from anything in the car when it's disconnected; no ground potential, no short-circuits.
      • Rob A.
        • December 1, 1991
        • 2126
        Wayne,
        Is the battery cutoff switch installed to prevent the battery from running low, from sitting for long periods, or is there a safety issue involved as well? I drive my car almost daily so battery cranking power is not a problem for me.
        • Wayne K.
          • December 1, 1999
          • 1030
          Rob,
          I installed one as my car sits all winter and even during driving season it will sit sometimes for weeks without use. It is much easier to turn the nob or lift the lever to disconnect the ground than to mess with the cable. The purpose as you have mentioned is to keep the battery from running low.
          Wayne
          • Brian M.
            • February 1, 1997
            • 1840
            I prefer the Blade type switch, it looks like a much better connection.
            • Chuck S.
              • April 1, 1992
              • 4668
              That would be response to the question as well, Brian...wouldn't use the green knob. I've heard too many stories of fires, shorts, etc. with the knob.
              You only have to look at old-timey high voltage switch gear to see which is the better connection...three synchronized blades on disconnects; one for each phase.
              • Gary S.
                • July 31, 1992
                • 1632
                I am one of those that had personal experience with the green twist knob for a battery cutoff. Too many times I got to go and really honk down on the green knob to get get current flow. The blade type has solved all of my problems.
                You use the negative side so you never have to worry about creating an indavertant short to ground with the switch on the positive side.
                Gary
                • Joe M.
                  • February 1, 2005
                  • 590
                  Check out the battery cutoff switches found in marine supply stores. Lot of different configurations and all heavy duty as their purpose is to prevent explosions when refueling a boat.
                  • Donald M.
                    • December 1, 1984
                    • 498
                    Gary, you are 100% right about the blade-type cutoff switch. It's the only way to go--much better/safer than the green knob ones. I believe it is called a "Save-ty" Switch, they're adverised in most of the Corvette magazines and probably in the Driveline.
                    Don
