'69 part help needed - NCRS Discussion Boards
  • Marc R.
    • April 1, 2004
    • 288
    I'm trying to locate the part number for the 1/2" or 5/8" hose that runs from the evaporator box to the rear of the blower motor. If I could locate the GM part number, perhaps I could find some place that reproduces it. I had no luck with my AM.
  • Dick W.
    • 10483
    Re: '69 part help needed
    Pt # 3015608 Do not know if it is still available, but I believe it was used on all car lines from 68-72. I would suspect that later tubes would also work but am not sure.
    Dick Whittington
    • Marc R.
      • April 1, 2004
      • 288
      Dick, With the part number you so kindly supplied, I searched www.partsvoice.com and found one in Napa, CA. The web is quite helpful for finding old parts. Thanks.
        • 43221
        Dick and Marc-----
        GM #3015608 is the correct part number. These tubes were used for cars with A/C as a cooling aid for the blower motor. Unfortunately, GM #3015608 was discontinued without supercession in September, 1986.
        I don't know if later (or, earlier) tubes will work, or not. However, it's moot since ALL of these tubes for 64-82 Corvette models are long-since discontinued. As far as I know, they are not currently reproduced.
        • Marc R.
          • April 1, 2004
          • 288
          Joe, I found an NOS on the website I listed. It's enroute.
            • 43221
            Marc-----
            That source in Napa, CA usually sells items for ASTRONOMICAL prices and I do mean ASTRONOMICAL. How much did you have to pay for it?
            • Marc R.
              • April 1, 2004
              • 288
              Yeh, I know...too much...way too much, but I got it.
              • Geoff C.
                • May 31, 1979
                • 1613
                What was the astronomical price? *NM*
                • Geoff C.
                  • May 31, 1979
                  • 1613
                  Was the shipping astronomical ? *NM*
                  • Geoff C.
                    • May 31, 1979
                    • 1613
                    Ben Dover *NM*
                      • 43221
                      Re: Ben Dover
                      Geoffrey-----
                      "Ben" definitely works up there in Napa. I have some familiarity with the place as I've been up there once (a long time ago). In fact, I actually got a pretty good deal on an NOS 1969 steering wheel there once-upon-a-time. But, what I had to go through to actually get that wheel was a REAL ordeal. I think that "Ben" figured that he had quoted me too low of a price since I didn't try to "haggle" with him over it (I NEVER "haggle" over price. If it's a fair price, I buy it without "haggling", even if I could "haggle" and get it for less; if it's too high, I pass unless I'm DESPERATE for the part. RARELY EVER happens with me. In this case, I already owned 2 NOS examples of the steering wheel, so I didn't really NEED theirs [NONE are for sale, now, though]). In any event, "Ben" tried to "back out" of the sale after he had given me his price ($400 and this was about 7 or 8 years ago) and I had agreed to it. I pressed him on it, though, and he finally came through. It took me 2 trips up to Napa (about 75 miles from here) and a BUNCH of phone calls to do it, though.
                      Several years later I called them about an NOS upper hood latch plate for a 68-E69. I didn't identify myself when I called so he didn't know it was the same guy that had bought the steering wheel years previously. His price for the plate? $600 and that was his "wholesale" price as he thought that I was a dealer. Since the plates on my car are perfect and I have several other NOS spares [none for sale], I wasn't "desperate" enough to pay that kind of price.
                      If you ever find yourself in Napa, CA stop in and see "Ben". This is a REAL, REAL strange place IN EVERY WAY. In fact, if I recall correctly, the guy's name is Craig COENEN or COEN (or, something very similar to that). I hope he's not related to you. Even if he is, everything I've said still applies, though.
                      • Geoff C.
                        • May 31, 1979
                        • 1613
                        Re: Ben Dover
                        Joe,
                        I'm not familiar with this place or "Ben". And he is no relative of mine. My last last was VonCoenen, but in the late 30's my Grandfather emigrated and changed it because everyone called him the soup ****.
                        Geoffrey Coenen
                        PS Joe you got any of those 68-82 AC blower motor hoses? Probably only $20 NOS if you know where to look.
                          • 43221
                          Re: Ben Dover
                          Geoffrey------
                          I'm pretty sure that his last name is very similar, if not the same, as yours. It just occurred to me as I was putting the last post together; I had never even thought about it before. When I was up there on the "premises" so long ago, I recall seeing it on something that was hanging on the wall. I remember thinking that I had always assumed that the name of the place was based on the owner's last name but, instead, it was the owner's first name.
                          This guy would NEVER pass as your brother, though. However, he is a bit eccentric and cantankerous. Believe it or not, in that regard he could put you to shame (now, that's something that a lot of folks might not think would be possible, but it's true). In fact, if folks would just go up and do business there, they'd appreciate what a kind, sensitive, warm, generous, empathetic, philanthropic, and tender-hearted sort of guy you are.
                          As it turns out, as shocking as it may be, I don't have any of those tubes in the collection. I've always sort of "shunned" group 9 parts (from 9.169 to 9.282). That's because I was never an A/C guy, never ordered it when I ordered my 69, and never really wanted to collect any of those parts. I like A/C now, though, but it's too late for my 69. I do have A/C parts in the collection for my 92, however. Like I say, I like A/C now.
                          I didn't realize that there was a single one of those 68-72 tubes anywhere within the land of the "Mohican Sun".
                            • 43221
                            Addendum
                            By the way, just so no one gets the wrong idea, just because I changed my mind about C-60 over the years, don't think that the same thing's going to happen relative to my feelings about side exhaust, tri-power, and 68-69 L-88/ZL-1 hoods. That absolutely AIN'T going to change. Ever. Period.
                            • Tracy C.
                              • July 31, 2003
                              • 2739
                              Re: Addendum
                              Well Joe,
                              The really cool thing about never changing your mind about these items, is that you will never need to post "(none for sale)" following an admission of ownership of them.
                              there is a positive side to everything ya know...
