Since I have prety much solved the cooling problem on my '61 thanks to everyone who helped out, my next priority is the vibration I have starting about 1800 rpm and gets worse around 2200 rpm and tapers off, but never quits up to 3500 rpm. For some background, I had this problem, but not as severe prior to pulling the engine. The engine is a later model 283(starter mounts in the block). It vibrates in neutral, so it is not the driveshaft. I changed the bellhousing to the orginal and found I had a 153 tooth flywheel. I found a used Hayes 168 tooth flywheel that appeared to be in good shape and installed it. The crank is an automatic with a dowel pin hole which lined up with the one on the flywheel. If my flywheel, pressure plate and engine are all internally balanced, where is the vibration coming from? It really shakes the whole car. I already checked the motor mounts. You can acutally see the rear of the engine shaking. I'm close to pulling the transmission and installing a new flywheel, clutch and pressure plate. I'd appreciate any input before I do this.
thanks.
thanks.
