Group 9.023 Body Mount Cushions c2 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    I have two types of rubber cushions from the parts group 9.023. I assume both are "service replacement" but don't know why they are different. One is 3842914 and the other is 3842913. As I recall, the 913 version has a metal washer embedded on one side. The other version is 100% rubber. Why?
    Tom Dingman
    member number 4889
    p.s. Note that www.MichiganNCRS.com will now direct you to www.MichiganNCRS.org
    (Michigan Chapter Site)
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Group 9.023 Body Mount Cushions c2
    What year Corvette you doing??
      • 43222
      Tom-----
      The number 3 and 4 body mounts on mid years use a 2 part cushion. For the number 3 position, the GM #3842914 is used on the upper part of the "sandwiched" assembly (above the body) and the GM #3842913 is used lower (below the body). For the number 4 position, the cushion installation is reversed.
      The GM #3842914 is a 1 piece part, manufactured entirely of an elastomer. The GM #3842913 is a 2 part assembly consisting of an elastomer and an "integral" steel reinforcing "washer". The GM #3842913 is discontinued while the GM #3842914 remains available. Both are available in reproduction, though.
      • Tom D.
        • 2134
        Roy - It's a 1966 - Thanks to both of you. *NM*
        Michigan Chapter
        Tom Dingman
        • Roy B.
          • February 1, 1975
          • 7044
          Re: Roy - It's a 1966 - Thanks to both of you.
          Tom
          I'm a bit dum on C2's tho I have a 67 for 24 years. poor me!!
