tri-power vacuum lines - NCRS Discussion Boards
  • kelly theaker
    the secondaries on the 69 tri-power end carbs have a vac line coming from the primary carb, i am under the impression these lines should have a white stripe? and the vacuum advance line also should have a white stripe? are clips used at the nipples on these lines?
  • Geoff C.
    • May 31, 1979
    • 1613
    clips as in clamps? NONE
    Yours truly was the first source of this item in the Corvette aftermarket. It even generated a debate about the width of the White stripe. Although not referenced in the AIM. I did find a reference to it in one official GM publication. I'm guessing, but it was about 15 years ago when I first saw it on a 5K mile 1963. Then on a friends 1962. It even found it on a 1970 I bought part of lasr week. Now its so common, probably Home Depot carries it.
    Whitey F*rd
    • kelly theaker
      Re: clips as in clamps? NONE
      Thanks for the response, is the white stripe vac line used for wipers and such the same or is the white stripe / aligator print under the dash for wiper over-ride the correct pattern.
      • Geoff C.
        • May 31, 1979
        • 1613
        Patterns come from very thin application of material (ink, paint) on the hose. At the other extreme are runs from too much.
        Geoffrey Coenen
