427 crankshaft - NCRS Discussion Boards
427 crankshaft
  • Cliff A.
    Infrequent User
    • January 1, 1994
    • 5
    427 crankshaft
    I am in the process of rebuilding my 67 427/435. The engine had a 7115 crank in it but it was pretty beat up and had to be turned 10/20. I also have a brand new nitrided 3856223 crank. I am leaning towards having the 6223 cross drilled and using it. Either way everything will be balanced. I would appreciate any input on this. Thanks, Cliff
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 427 crankshaft
    unless you are planning to race the car i would not cross drill the crank because it is not needed for under 7000 RPMs,just get it magnafluxed.
    • Cliff A.
      Infrequent User
      • January 1, 1994
      • 5
      Re: 427 crankshaft
      Thanks Clem , I will have the 6223 crank magnafluxed and checked to be sure it is straight before using it. From your responce I assume that you think the fresh crank would be the best choice of the two. Thanks, Cliff
      • Joe R.
        • July 31, 1976
        • 4550
        Re: 427 crankshaft
        Cliff,
        When Clem speaks on engines--just listen! Do what he says and your 435HP/427 will live to run again and again.
        He helped write the bible on performance engines long before we were a twinkle in our daddy's eye.
        JR
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: 427 crankshaft
          i ain't that old.
          • Clem Z.
            • January 1, 2006
            • 9427
            Re: 427 crankshaft
            just radius the oil holes in the crank with a die grinder and a 3/8" diameter mounted grinding wheel to form a small trough on both sides of the oil hole drilling so you have a lead in area for the oil.
            • Chuck R.
              • April 30, 1999
              • 1434
              Re: A question for that hot rod kid Clem
              When you speak of die grinding the oil holes, are you speaking of a slight groove straight across the entire bearing surface on either side of the hole, or just oblonging the holes edges slightly?
              Thanks Clem,
              Chuck
              • Clem Z.
                • January 1, 2006
                • 9427
                i just put a groove across the oil hole the width of the hole by going straight down with the side of the 3/8" diameter by 3/4' to 1" long stone till it reaches the width of the oil hole. you end up with a oval shaped groove cut into the journal.
                • Chuck R.
                  • April 30, 1999
                  • 1434
                  Re: Sorry Clem you lost me at the bakery
                  I just can't envision what your explaining.
                  Could you by chance send me a rough sketch?
                  What can I say, I've been challenged for years and it's getting worse.
                  Chuck
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    send me your e mail address and i will scan a picture to you.
