C2 Protect-O-Plate decoding - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    (1966) Should the protect-o-plate be stamped the same as the engine, trans, and rear end? I know that the p-o-p has an "H" after the engine code. Example: Let say the engine is stamped: F1209HT, the p-o-p would read: F1209HTH. Is there anything different with the trans or rear end codes? (rear end is stamped : AS113065, and the tranny is: P1123) Is this what should be on the p-o-p?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 Protect-O-Plate decoding
    Ken the first year as I understand it for a Corvette to have the "POP" was 1967. Do you have one for your 66 Corvette?
    • Rob A.
      • December 1, 1991
      • 2126
      I have a '66 with an original POP. (Tank stickers, however were not installed until '67)
      • Kevin M.
        • November 1, 2000
        • 1271
        Rpb,
        In Noland Adams book he says some might have appeared on late 66's, just happened to read it yesterday.
        Kevin
        • Wayne M.
          • March 1, 1980
          • 6414
          P-o-P's began at the start of 1965 Model Year *NM*
          • Jim T.
            • March 1, 1993
            • 5351
            Re: P-o-P's began at the start of 1965 Model Year
            I stand corrected, I knew the tank stickers started in 67, and only thought the "POP" started in 67 as well.
            • Ken K.
              • May 31, 1999
              • 235
              Re: Still looking for my answer about p-o-p codes
              Thanks for the great info, but no buddy has answered my original question about the proper protect-o-plate coding.
                Director Region V
                • August 31, 1994
                • 1463
                Yes, plus the paint and interior codes. The 'H'stands for Holley.
                H. a. N. D.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Trans the same; Rear with a "W" after the ratio..
                  ..code and date (for Warren MI assy plant). There's also a single letter designation for month of vehicle production, and the Chev bowtie. Format varied from '65 thru '67. If you have your AIM (Assembly Instruction Manual) there's a page showing codes and location on the card.
                  • Gerard F.
                    • June 30, 2004
                    • 3806
                    Attempt from a 67 POP
                    Ken,
                    This is from a 67 which may be different then a 66
                    Rear End: AS113065 The 67 pop would have AS1130W meaning 327 3.70:1 (AS), November 30 (1130), Warren Plant (W)
                    Transmission: P1123 The 67 pop would have P7S30D(or N) meaning Muncie 4 speed (P),
                    Nov 30 1967 (7S30), Day or Night Shift (D or N). Maybe the 66 just has the P1123 followed by a D or N
                    Engine Code F1208HT The 67 pop would have F1208HTH meaning Flint Motor Plant (F or V), December 08 (1208), 327/350, 4 speed, highlift cam, 4 bbl (HT) holley (H)
                    Maybe someone with a 66 POP will chime in, I think the only difference is in the transmission date code where they used a letter for the month.
                    Hope this helps,
                    Jerry Fuccillo
                    #42179
                    Jerry Fuccillo
