Thanks to Joe Lucia on this heater box. - NCRS Discussion Boards
  • Jim #42767
    Thanks to all for your advice on how to fix my broken heater box. I used Joe's method of JB weld here is the result.
  • Jim #42767
    Re: Thanks to Joe Lucia on this heater box.
    Turned it into this.
    • Kevin M.
      • November 1, 2000
      • 1271
      Nice work.
      Kevin
        • 43240
        Jim------
        Now just make sure that you don't overtorque the nuts when you re-install the box. If you do, you could break it off again (or, break off one of the other ones). The correct torque is 35-50 pound-INCHES. That won't feel like it's "enough". But, it's enough.
        • Ryan Clark
          Looks pretty good. Can you post the method that was used. I have a similar situation I will have to work on this spring.
          Ryan
          • Jim #42767
            I used the JB weld method. After it dried, i used my die grinder with a small wire brush to dull the finish of the JB weld.
