62 chassis - NCRS Discussion Boards
62 chassis
  • mike androwick
    62 chassis
    On a frame off resto, should all the various nuts and bolts be painted or is there some kind of clear coat i can put on them to keep them from rusting.
    thanks again!
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 62 chassis
    Mike, Almost none of the nuts, bolts or washers were originally painted. Many were cad/zinc plated and that gave reasonable protection from rust. On the items not plated, I would clean with a wire brush on a grinder and then give them a light coat of dull satin clear if you live where rust is an everyday issue. If judged, paint or obvious clear will likely cause a small deduction. Best, Dennis
