71 454 vacuum check valve - NCRS Discussion Boards
  • Mike S.
    • March 1, 2005
    • 125
    I had rough idle .block off vacuum port to vacuum resivoir.rough idle gone.lights and wipers work fine when hooked back up.could not find any vacuum leaks. so i replaced vacuum check valve . idle fine .but lights wont pop up. any thoughts.
  • Mike S.
    • March 1, 2005
    • 125
    Re: 71 454 vacuum check valve
    I reinstalled old vacuum ck valve lights pop up .but rough idle.
      • 43203
      Mike-----
      I'd guess that the new vacuum check valve is defective. It's preventing any vacuum leak (that's why the idle smoothed out), but it's not allowing any vacuum to build in the tank or the vacuum system (that's why the lights won't come up).
      • Mike S.
        • March 1, 2005
        • 125
        its an after market check valve.is there oem still offered?is there any in the check valve to keep the vacuum from afecting the engine?thanks
          • 43203
          Mike----
          The GM check valve is discontinued. The check valve simply prevents the leak back of vacuum from the resevoir tank after engine shut-down. If it leaks, though, it can cause a vacuum leak during engine operation and, thus, a rough idle.
          • Mike S.
            • March 1, 2005
            • 125
            Re: THANKS Joe *NM*
            • Mike S.
              • March 1, 2005
              • 125
              Re:joe ZL1
              Joe hows your ZL1 coming.Mike
                • 43203
                Re:joe ZL1
                Mike-----
                I'm hoping to finish the engine "tomorrow". "Tomorrow" is the absolute best time to finish any project.
                • Mike S.
                  • March 1, 2005
                  • 125
                  Re:joe ZL1
                  should be nice ride. hope everything turns out well for you.thanks for all the info.mike
                    • 11622
                    Mike,
                    I believe there is more than one company is reproducing the check valve. At one point one of them was allegedly advertised as "more correct" in internal construction. I can't verify that is was or was not.
                    Patrick
                    • Mark #28455
                      check valve backwards?
                      Is it possible you installed the valve backwards? Try to suck air through the original and the repro. If it's backwards, it won't leak but the headlights won't work either. Did you visually check the vacuum reservoir? Over time, they commonly crack in the reinforcing grooves on both sides. If you want a cheaper fix than replacing, you can braze the cracks and it'll probably last another 20 years.
                      Good luck,
                      Mark
                      • Mike S.
                        • March 1, 2005
                        • 125
                        Re: checkvalve
                        any one know of a good mfg for check valves.
                          Re: checkvalve
                          Chicago Corvette tends to specialize in carb parts that that aren't available elsewhere (Holley, Carter, & QJet). You might check there before concluding this/that can't be found....
                          • Dick W.
                            • 10483
                            Re: checkvalve
                            Most of the vendors carry them. They were originally made by Trico for GM but never available thru the Trico distribution system to retail customers.
                            Dick Whittington
                            • Mike S.
                              • March 1, 2005
                              • 125
                              Re: thanks guys *NM*
