66 427/425 L72 Intake Gasket - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Were factory original intake manifold gaskets sculpted to follow the exact pattern of the intake manifold - ie no excess gasket material showing ?
    Thanks for your input.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 66 427/425 L72 Intake Gasket
    Thats what I've heard... however I sculpted a gasket in that fashion and, lo and behold, the cavities around the exhaust crossover in the manifold were exposed (67 L36 4 barrel). Hummm that doesn't look right. I then referred to my Service Manual which just happened to have a photo of a big block with the gasket in place but the manifold removed (page 6-26 in the manual). I then sculpted a gasket to that configuration and it covered the cavities and fit perfectly. That is my story and I'm stickin' to it!!!
    • Peter M.
      • February 1, 1984
      • 361
      Steve - I saw the picture you referenced - not sure if that was a replacement gasket or not - Anyone out there have a survivor example ??
      • Stephen L.
        • May 31, 1984
        • 3158
        Peter, if you trim the gasket to the exact shape of the manifold then the cavities around the exhaust crossover will be exposed. I have photos showing that. I don't believe this is correct. Send an e-mail and I'll send the photos.
        Aftermarket gaskets need t*******: its a matter of how much.
