1960 leaf springs - NCRS Discussion Boards
1960 leaf springs
  • Steven J. Neel
    1960 leaf springs
    Do the short length of springs go forward or to the back of the shackle. also where do you place the banding pieces. Is there 2 or 3 bands per side. Also when spraying your chassis number on the frame, do you spray from left to right or right to left and which hand is best to use to hold can.
  • Jerry C.
    • November 1, 1995
    • 741
    Re: 1960 leaf springs
    There are three bands per side. When doing your frame stencil I have found if you get a small roller and spraying your paint on cardboard and putting it on the roller and let it get almost dry before you roll it on works best. If you try to spray it on it runs to the inside of the stencil and you will be doing it several times. It was rolled on from the factory and I have had points taken off for spraying it.
