1969 Quadrajet Carb problem - NCRS Discussion Boards
  • Ed M.
    • August 31, 1996
    • 52
    I am having a lot of problems finding a replacement fast idle cam for my 1969 427/390.... junkyards and suppliers were not helpful. Mine is plastic and is cracked... I am sure that it has been upgraded at some point? Suggestions????
  • Steve Antonucci
    Re: 1969 Quadrajet Carb problem
    Ed,
    Contact Phil Cancilla @ Custom Rebuilt Carbs. ( thecarburetorman@aol.com )
    I'm sure he has either a good replacement for you, or can get you what you
    need. Incidently, Phil does all of my carb restorations.
    Steve
      • 43221
      Ed----
      The fast idle cams for your application are GM-discontinued. If you car is an automatic, then you are looking for cams of either GM #7038845 or 7036820. If it's a 4 speed, then you need GM #703844 or 7036819. These are "around"; they shouldn't be too hard to find.
      • Harold #43147
        Carb
        I have not seen a plastic one does it have a arm and teeth on the bottom. I will check my parts with the #'s Joe gave do you have a picture of it? If I have one you can have it N/C let me know
          • 43221
          Re: Carb
          Harold----
          Yes, these 68-69 carbs originally used a plastic fast idle cam. There were different colors denoting different applications. One was "whitish", another green, and another red. These pieces often crack with heat and age. They do have an "a-arm" and "teeth" (steps) on the bottom, just like the metal variety. However, they are much thicker in cross-section than the metal type.
          Many of the replacement carbs for 68-69 applications, as well as many other Q-Jets used a metal cam. I don't think that these can be retrofitted to original 68-69 carbs with the plastic style cams.
          • Ed M.
            • August 31, 1996
            • 52
            Re: Carb
            Hey guys, thanks for the response!! It is for a 4-speed and the color now is kinda tanish (so I think it was originally white?) I don't have a photo of it at present. The body is thick.
              • 43221
              Re: Carb
              Ed-------
              Yes, that's the GM #7038844. Later examples of this piece might be a different color (red, if I recall correctly). The early ones were "whitish" or "tanish".
              • Harold #43147
                Carb
                Bought a core carb from a guy says it has a plastic cam I have 3 69 350 carbs all have metal but they were probably rebuit I wonder if the rebuilders were putting metal ones on like I said I have never seen one I will let you know when I get it maybe a dup could be made with casting resin I am working with these plastic casting resins for making patterns looks just like injection mould peices been thinking about trying to dup my 5 port washer pump
                • Ed M.
                  • August 31, 1996
                  • 52
                  Re: Carb
                  Harold thanks for the reply.... let me know if you come up with something.
                  Ed
                  • Harold #43147
                    Carb
                    Ed I don't have a plastic one I have never seen one the only thing I can figure is that buy the time these carbs got around to me they were probably rebuilt and I would think the rebuilders might have replaced them with metal ones. Do you have the cam off the carb? If so send me a pic or send me the part and I can see if the metal ones will work. They were probably discontinued because that part made of plastic would not last very long on a car that was driven daily. I bought a core carb for parts that I need for a carb Iam working on and the guy says it has a plastic cam on it (RED) I haven't recieved it yet.
