C - 2 63 - Production Numbers - NCRS Discussion Boards
  • Jim#11474
    Would any know how many 63 Coupes where made with the following options?
    Saddle
    Saddle Leather
    340 HP
    Power Windows
    Power Brakes
    Metallic Brakes
    AM/FM
    411 Axle
    White Wall Tires
    4 Speed
    My car was produced March 29th.
  • Harry Sadlock
    Re: C - 2 63 - Production Numbers
    Jim, can't tell you, but you have a car built with one of the first AM/FM radios. You VIN sequence should be somewhere around 11768. If you ever pulled the radio, the radio Identification Number will probably be close to 86-FMA-0001.
    Let us know.
    Harry
    38513
      No records were kept of volumes for all the many possible combinations of styles, colors, and options; only of individual items.
      • Mike L.
        • January 1, 1986
        • 312
        Harry, my car is thousands of Vin numbers earlier never taken apart before I purchased it (3 owner car)and I have a factory AM/FM radio. How are you comming up with your numbers?
        • Harry Sadlock
          Mike, from what I have seen and from what research I have done, VIN sequence 11768 is where AM/FM radios started as normal production in 63. Also, best I can tell everything production for retail sales prior to that was AM. The 63 AM/FM radio was number 985686. The tag on the radio for the first AM/FM would have carried a radio identification number of 86-FMA-0001. As an example, VIN Sequence number 13356 has radio 86-FMA-1594. 13356 minus 1594 equals VIN Sequence number 11762. Taking into consideration very few radio delete cars 11768 feels correct.
          Harry
          38513
          • Harry Sadlock
            Also, the 11768 number is a point of reference in Nolan's book, page 162, where they went into full production. With what I found I think it's correct. There were a few installed prior to that number, but just a handfull.
            Harry
            • Loren L.
              • April 30, 1976
              • 4104
              If your car is "thousands of VIN numbers earlier", it has THE WRONG RADIO. AM-FM radios were NOT SHIPPED to St Louis until March 1.
              • Loren L.
                • April 30, 1976
                • 4104
                Harry, you may be the only person in
                the world that actually beieves AM-FM radios were installed on a first in first out basis.
                • Harry Sadlock
                  Re: Harry, you may be the only person in
                  Loren, I did not indicate the First-in First-out methodology, I'm not sure how you copuld assume I did. I have an examples for later years where it is quite the reverse.
                  Harry
                  • Jim#11474
                    Harry,
                    My vin# is 11800, can I read the numbers off the radio without removing it?
                    Jim
                    • Harry Sadlock
                      Jim, possibly. Sometimes it was stuck to the side (right or left), but many times it was on the front.
                      Harry
