bonding strips - NCRS Discussion Boards
bonding strips
  • Curtis L.
    • August 31, 2003
    • 120
    bonding strips
    What are they, where located & how to tell when they are original. Thank you.
  • steve principle
    ask this guy
    he claims to own not one, but four Corvettes
    • Chuck S.
      • April 1, 1992
      • 4668
      Re: bonding strips
      Bonding strips are narrow pieces of fiberglass, maybe 2"-2.5" wide, that serve as reinforcement of the bonding seams between body panels.
      Major bonding seams like fenders are usually butt joints where two fiberglass panels are "butted" together (more or less) for a smooth joint with a bonding strip behind the joint for strength; the panels are actually bonded to the bonding strip rather than each other because the edges of the panel provide no significant bonding area. In addition to the "butt joint", several other types of bond joints were used, which may or may not, require bonding strips.
      During the factory bonding process, major body components would have been assembled/bonded together on jigs, and finally the entire body would have been bonded together on a jig. The bonding adhesive would squeeze out of the joints, and the first step in paint prep was to grind off the excess adhesive to a smooth contour on the exterior body surfaces. I believe they did use a type of fiberglass adhesive filler if the adhesive had voids, but it appears to me that the objective was to avoid it if possible.
      On the back side of bonding seams, you can still see the bonding adhesive squeezed out of the joint just like it was the day the body was built; or, you may see where they have removed/smoothed the REALLY BIG gobs and drips with a gloved hand.
      • Mike Cobine
        Re: bonding strips
        In the last picture on this page, you can see the bonding strip on the side louver panel.
        Here are some examples on ebay:
        '68-'69 exhaust opening
        midyear nose
        midyear taillight strip
        Original Fiberglass
        • Curtis L.
          • August 31, 2003
          • 120
          Re:Thank you Chuck *NM*
