C2 washer nozzle pattern - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    Does anyone know how to adjust the spray pattern out of C2 washer nozzle? Or is that one of those things that can't be changed? Mine hit the windshield in the correct area, but it's pretty much a straight line of water. Thanks.
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Brian M.
    • February 1, 1997
    • 1839
    Re: C2 washer nozzle pattern
    Rob, are they the original type with the Brass ball's? If so spray a little PB Blaster on them and let it sit overnight, stick a straight pin or pic in the orafice and move the ball around a little. That should do the trick.
    • Rob M.
      • April 30, 2003
      • 657
      Brian,
      They're original with the brass ball inside. What's PB Blaster and where do you get it?
      Rob
      Rob
      '08 6 speed coupe
      • Earl G.
        • September 30, 2001
        • 66
        Rob,
        It is a break-free product that really works. PepBoys.
        Gunner
