C1 turn signal assembly help for 60 - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    Is there any good drawings/assembly instructions available for the horn/signal/canceling mechanism. If it's in the Aim or ST12 I can't find it.
    Larry
  • Ed Jennings
    Re: C1 turn signal assembly help for 60
    I don't remember any right off, but it's pretty straightforward. What do you need to know?
    • Larry P.
      • June 30, 1999
      • 481
      I have a box of parts that include
      Cancel mechanism with two coil springs
      Wire harnes with two screws
      lock wedge with screw
      centering spring
      horn contact
      1 wire tension spring (about 4" long)?
      2 pan head bolts with nuts 1 1/8 x 1/4
      2 countersunk head philips about #10 1 1/8 long
      From catalogue drawings I am missing the pivot bolt and
      the brush and the screws for the horn contact
      I don't know if I have everything or what doesn't belong.
      I have everything orientated. Is the wire spring from somewhere else?
      How does the horn/brush make a connection for ground to the horn?
      I remember something about shiming pins for the signal canceling.
      Larry
      • Roy B.
        • February 1, 1975
        • 7044
        If you have C&C catalog book on page 119 should help you.The horn brush rides on the Horn copper ring .
        • Ed Jennings
          Sounds like you have everything except the pivot bolt. The 4" tnnsion spring must be for something else. Like Roy says, the brush just rides on the rim of the upper bearing which doubles as the horn contact.
          The pins on the hub of the steering wheel must be oriented to the 8 and 10 o'clock positions in order for the cancel mechanism to operate properly.
          • Larry P.
            • June 30, 1999
            • 481
            Are you sure about the 4" spring? I see a "W" spring #561113 in CC's Catalogue.
            They say it's part of the canceling mechanizm.
            Larry
            • Roy B.
              • February 1, 1975
              • 7044
              There are two little springs about 1/2 long #561109 that pull the cam lever and one long flat spring steel #561112 piece about 3in., no other spring used in the housing.
              • Larry P.
                • June 30, 1999
                • 481
                CC insists that there is a wire spring that mounts on the canceling switch #561113 that is needed. It is listed but not shown in the picture.
                Larry
                • Dennis A.
                  • April 30, 1999
                  • 1010
                  Larry...
                  There is a wire (spring) that mounts on the cancel switch that pivots with the switch. Most switches have this installed as part of the assembly, it can come out and if bent-in will not work.
                  • Larry P.
                    • June 30, 1999
                    • 481
                    Dennis,
                    I was just getting ready to respond that I found YOUR picture of the assembly showing the wire spring on the right side with tension to the legs outward.
                    Thanks again, I'll just bring a case of beer.
                    Larry
                    • Dennis A.
                      • April 30, 1999
                      • 1010
                      Re: C1 turn signal assembly picture *NM*
