66/67 BB Bellhousings - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    Do the 66/67 judging guides not deal with the casting numbers of bellhousings? Are these not judged at all? What are the correct casting numbers for 66 427/390 and 67 427/435 cars. Thanks.
  • Mark L.
    • 561
    Re: 66/67 BB Bellhousings
    Rick, The 66 bellhousing is 444 and the 67 is 621 for big blocks. The complete numbers are present in the manuals. Good luck. Mark
      • 43221
      Rick and Mark-----
      Yes, most, if not all, 1966 Corvette 427s used bellhousing GM #3872444 and 1967 427s used bellhousing GM #3899621. These bellhousings are, I believe, functionally interchangeable, though. Both are designed for use with a 14"flywheel(168 tooth ring gear)for an 11" clutch.
      1964 thru 1967 Corvettes with 327s and 1965 Corvettes with 396 used bellhousing GM #3840383(sometimes identified by the number 3858403). It is possible that some 1966 L-72s also used this bellhousing. This bellhousing is designed for use with a 12-3/4" (153 tooth ring gear) flywheel for a 10.4" clutch.
      • Richard S.
        • November 1, 1994
        • 809
        Where in the 66/67 judging guides can I find the specifics on bellhousings? Thanks.
        • Wayne M.
          • March 1, 1980
          • 6414
          • Richard S.
            • November 1, 1994
            • 809
            Wayne, thanks for helping me out re. the bellhousing judging. It looks like Dan in Hamilton may have grills I can get in a hurry.
