C2 Tie Strap Question - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    I'm replacing the original cracked and useless washer hoses on my 66 and I have a pretty lame question regarding the tie straps. Bubba took the original tie straps with him, so I don't have any to go by. The AIM shows the washer hose and the hood release cable strapped together (driver's side), was the wiring harness supposed to be strapped with them? And, regarding the orientation of the tie strap, should the strap be installed going under to over in a counter clockwise fashion, or over to under in a clockwise motion? If that even makes sense or does it even matter? Thanks for the help.
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Mike M.
    • September 30, 1999
    • 710
    Re: C2 Tie Strap Question
    Wiring harness should go in the firewall clips.
    • Brian M.
      • February 1, 1997
      • 1839
      The wire harness is supported by 1 J clip on the fire wall then hung from the hood release cable which is secured by 3 clips.
      • Mike M.
        • 710
        Brian, You got it just looked under my hood and the wiring harness is only in the right side firewall clip. My memory is getting bad. mike
