55-56 wiper motor - NCRS Discussion Boards
55-56 wiper motor
  • Roy B.
    • February 1, 1975
    • 7044
    55-56 wiper motor
    I Just got a NOS in the box 55 Chevy truck wiper motor from E-Bay, and your asking sooooo. Well because I know if you remove the bottom plate and replace it with your original plate you have a new original wiper motor.Even the top steel cover is the same but for the ##'s so if you 55 or early 56 guys have a bad wiper motor and have around $150.00 check now and then on Chevy 55 truck. Or get a rebuilt one from you no who for $600.00 or more.
    AND look for a 55 "truck" gas tank sender, it also is the same as 55 Corvette.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55-56 wiper motor
    Here is one on e-bay cleaned rebuilt and ready to go starting $25.00 . You can see that the back plate lid is different and as I said just replace it with your's.
    • Roy B.
      • February 1, 1975
      • 7044
      As you also can see the front plate is the same but for the ## I may bid my self replace the bottom with any C1 plate that will also work , then sell it for bigga bucks as Corvette. Were do you think many rebuild Corvettes wiper motors come from?
      Truck to Corvette!
      Car to Corvette!
      Thier cheep! Corvette bigga bucks guys.
      • Stephen J.
        • November 1, 1982
        • 24
        Thanks again for a great tip
        Thanks again for a great tip Roy. As I said before whenever you post some "pearl of wisdom" will be gained!
        • Bernard M.
          • August 31, 1994
          • 341
          The 924 ('56) switch cover won't fit this motor.
          It has a different shape at the right rear (as installed) corner.
