C3 window height adjustment - NCRS Discussion Boards
  • Ed Jennings
    On my 75 convertible, I need to raise one of the windows about 1/8". The window stops at least a 1/4" short of hitting the window stop on the center guide. Is there more than one window stop? The window is electric if that makes any diference.
  • Terry F.
    • September 30, 1992
    • 2061
    Re: C3 window height adjustment
    I only know of the two window track stop adjustments inside the door. Those tracks can also be adjusted for angle to make the seal tighter at the top of the door. Terry
      Add-on
      Backing what Terry says, the Chevrolet Chassis Service Manual for your year car has a chapter dedicated to the Corvette body because Corvette was NOT Body By Fisher as other cars were. In that section you'll find text covering door glass adjustment.
      Basically, the glass can be canted in/out with respect to the roof rail, the closed and open positions adjusted up/down and the absolute angle of the glass tilted fore/aft. What fasteners inside the door do what adjustments are depicted...
