62 Heater installation - NCRS Discussion Boards
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    There have been several recent threads on this and I thought I understood it until I went to the Judging Retreat in Dallas. There was a very nice Top Flight 62 used in the class that had the foam gasket outside the firewall (between the firewall and the fiberglass duct with the flapper valve in it). I would appreciate someone clarifying the specific order of the inner box, the sheet metal plate, the foam gasket, the firewall and the outer duct.
    Thank you for your patience
    John
  • Mike E.
    • February 28, 1975
    • 5139
    Re: 62 Heater installation
    John--
    Heater assembly is completely assembled before it is installed in the car.
    Therefore, you see the fresh air hose snout from the engine compartment, and then the foam gsket, behind the snout, butts up to the firewall from the inside of the passenger compartment. Other than the four attaching bolts, that's what you see from the engine compartment side.
    Hope that helps--otherwise, email me and we can go in greater depth.
    • John T.
      • January 1, 1983
      • 292
      Thanks Mike
      That explains it completely. The heater goes in tonight.
      John
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12778
        That will be a hot night then ;-)
        Rob.
        NCRS Software Developer
