Anyone used Just Dashes for restoring pads - NCRS Discussion Boards
  • Scott Marzahl
    Has anyone used or have experience with Just Dashes when it comes to recovering Corvette dash pads or should I go with A.K. when I get everything else for my '67.
    Thanks.
  • Allen W.
    • September 30, 2000
    • 106
    Re: Anyone used Just Dashes for restoring pads
    I used Just Dashes twice. The first time was on a porsche I restored . Many years ago. The texture was close but not matching. However the work was very good. Black color. The 2nd time was for a ford pickup. Grain and color (red)matched fine. Work equally good. Kind of pricy but result good. They fixed a split in the porsche dash and it has not returned. I would contact them about matching your Corvette grain.
    Allen
    • Boyan B.
      • August 31, 1999
      • 189
      I used Just Dashes on my 63. The pads and center section came out perfect. They can match all textures for Corvettes, just tell them what you need. I highly recommend them. My only complaint is that they are expensive.
      Boyan
      • Louis F.
        • September 30, 1991
        • 132
        Scott, i used Just Dashes in 1998/1999 to do 1965 black dash pads.My experierence wasn't a good one. They assured me the pads would come out PERFECT.When i received them, the thickness of the pad was significantly thicker then original.If installed they would have looked ridiculous.I called Just Dashes, spoke to someone in authority, and was told they would not adjust them.Essentially i was told, this is how we do them.In addition there services come at a stiff price. They may have changed now, but when i used them they were BAD.
        • John M.
          • January 1, 1998
          • 813
          Scott, I had the pads in my 67 reskinned with materials from Al Knoch. They are beautiful and the "re-skinner" did a beautiful job. But, if I were to do it again I would buy new Pads from Al knoch and install them myself, actually would've been cheaper. Forget Just Dashes.
          John 30025
