I need input on where to put decals on a standard suspension early 64 on the following? 1. Shock absorbers, front and rear, upper or lower section, inboard/outboard, distance from upper or lower mount. EK/EM label? Color? 2. Front Springs, ED, placed front/back/side and the number of coils from top or bottom? Color? 3. Does anyone know the correct labeling for the radiator and surge tank for an early 64, I am confused about placement of the green paper label, I'm ok on the foil, is there a inspection tag with the number 3 that goes on the radiator/and a inspection tag number 8 on the surge? Does the green label cover the part number/date code? Should there be a yellow rubber stamp with a CWT 10 mark?? What materials are the number 3 & 8 made of?
Thank you!
Thank you!
