Is there a certain brand paint for frame? - NCRS Discussion Boards
  • Barry S.
    Infrequent User
    • April 1, 2000
    • 2
    Is there a certain brand semi-gloss paint that is prefered for frame painting on a 1964? Thanks..
  • Dick W.
    • 10483
    Re: Is there a certain brand paint for frame?
    Everyone has their preferences on paint. If you are looking for lacquer, PPG DDL 9300 is very close. If you want a more durable finish, we have used single stage Deltron 9300 flattened to eggshell gloss. Looks good and very durable if applied correctly
    Dick Whittington
      • 43240
      Barry-----
      The original "paint" was not paint. It was an asphaltic coating that looked somewhat like paint. It was primarily designed to keep rust off the frame long enough for the car to be sold new. It was really not very durable, at all. You can still get it, but I don't recommend using it, at all. I'd go with a method like Dick mentioned. It looks very close to original and it's durable.
      The asphaltic coating is fine for "trailer queens" that "live" in temperature and humidity-controlled environments.
      • Erik S.
        • January 1, 2005
        • 407
        Dick, Joe - can I use the same brand for my 68? Or are there better alternatives (I know, I am lazy - apologies; I could have used the search option but now that the subject is at the table..........)
        Greetz,
        Erik
        Nederlandse club voor Corvette liefhebbers, met of zonder auto. Opgericht in 1993. Uitgebreid forum, meeting-agenda, fotoalbum en meer.
        • Dick W.
          • 10483
          Erik, the DDL 9300 is very close, if not the same, as the paint the you could buy from GM for detailing. The flattened 9300 Deltrom closely matches the gloss of the DDL. This should work for detailing at least thru 1982. I am not familiar as to what Corvette used on C-4 and up.
          Dick Whittington
          • Scott Marzahl
            I used PPG DP90 followed by flattened Deltron as well. If I had to do it all over again, I'd have it powder coated in a semi flat black. It's far more durable and I could have done it for less or equivalent cost wise.
