WCFB ID. - NCRS Discussion Boards
WCFB ID.
  • Harry Sadlock
    WCFB ID.
    I've stumbled across a rather nice WCFB. I just can't figure out what it is from. The air horn is 6-1575 and the body is 0-1342. Any ideas?
    Thank You
    Harry
    • 43240
    Re: WCFB ID.
    Harry------
    I can't tell you what its application is but I can tell you that I don't think it's for a Chevrolet application. These carbs were used on all other GM car lines, so it's likely for one of the others.
    • Mike M.
      • May 31, 1974
      • 8396
      Re: WCFB ID.
      harry: most wcfbs used on c-1's had 049 embossed on the left front corner area of the main body.the c-1 judging manuals discuss casting #s on the various carb parts. mike
        Re: WCFB ID.
        As others have said, it's not a 'Corvette' carb configuration, but the air horn and body cast numbers generally date the carb's usage to the early '60 era. Other car lines at GM (including the 'competition' like Studebaker), also used Carter WCFB so it probably has an application 'somewhere' PLUS it could be a Heinz 57 carb (ran down an independent carb rebuilder's reverse assy line resulting in body + air horn being mated for general functionality vs. factory originality reasons)....
        • Harry Sadlock
          Re: WCFB ID.
          Thanks all. I should have mentioned in my post that I had already been through Chevy and Corvette by the Numbers. Didn't mean to waste you time on that. Just thought it might be recognized as a old Mopar piece.
          Thanks again
          Harry
          • William C.
            • May 31, 1975
            • 6037
            Re: WCFB ID. No Tag? *NM*
            Bill Clupper #618
            • Harry Sadlock
              Re: WCFB ID. No, no tag. *NM*
              • Mike M.
                • May 31, 1974
                • 8396
                Harry: the mopar wcfb's i've seen had 1" embossed down in their throats for what its worth. mike
