Riveter Recommendations Needed - NCRS Discussion Boards
  • Rick S.
    • March 1, 2004
    • 14
    Power or Manual, Blind or Treaded Nut. Also what are the most
    common types of rivets used on a C1 '61. Thanks, Rick
    Re: Riveter Recommendations Needed
    I use a burp-gun regulated down to 15-20 psi and a .401" shank 3/16" rivet setter; most Corvette body rivets are 3/16" soft aluminum - Doc Rebuild and Paragon have the correct soft rivets.
    • Mark S. Lovejoy
      Adding to what John has posted. McMaster Carr sells a rivet setting tool. It has a concave face and holds the rivet head (round head rivets) when using the old fashioned hammer methode. Worked well for me.
      • Rick S.
        • March 1, 2004
        • 14
        • Dennis A.
          • April 30, 1999
          • 1010
          Rick...
          Using an Air Hammer, Shanks can be purchased form several corvette suppliers or Aircraft Tool supply ( they are on the web). Use a steel back-up block or a hammer head will do. Set the pressure at 15 - 35 psi and use 3/16 dia. X 1/2 or 9/16 long soft alum. rivets. Hold the trigger until the concave tool bottoms out. Best not use your wife to hold the back-up block....
