C1 radiator - NCRS Discussion Boards
C1 radiator
  • Pat #25912
    C1 radiator
    Should the brass date tag be painted gloss black with the rad or left natural?
    When installing a new drain tap, should anti-sieze be used or teflon tape?
    Thank you again. Pat G.
  • Mike M.
    • May 31, 1974
    • 8383
    Re: C1 radiator
    black like the tank. i use liquid teflon. mike
    • Chris H.
      • April 30, 1990
      • 817
      Re: C1 radiator
      Would Kelsey also be the right place to buy correct '62 tires?
      thanks, Chris
      • Mike M.
        • May 31, 1974
        • 8383
        Re: C1 radiator
        i used kelsey's on my 61. duntov'ed without problem. you have email. mike
        • Pat #25912
          Thanks Mike *NM*
          • Jon S.
            • November 1, 1992
            • 202
            Re: C1 radiator
            Chris, are you planning to order the goodyear custom super cushions? I think they are correct for a 62. I like the look of them so much better than the silvertowns that coker sells. Been thinking about ordering a set for judging myself. Regards, Jon
