'66 TANK TO PUMP FUEL LINE REPLACEMENT - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Can the tank to pump fuel line be replaced with the body in place?
  • Mike M.
    • May 31, 1974
    • 8396
    Re: '66 TANK TO PUMP FUEL LINE REPLACEMENT
    yes but its a PITA and much easier with less likelihood of bending a crimp in the steel tubing if ya pull the body. good luck, mike
    • Wayne M.
      • March 1, 1980
      • 6414
      If it's a SB, install BB line -- save next owner..
      ..the trouble. (from Barrett-Jackson helpful hints booklet)
      • Michael H.
        • January 29, 2008
        • 7477
        Re: If it's a SB, install BB line -- save next own
        I understand most of the suppliers of reproduction BB fuel lines are now out of stock. Can't keep up with the sudden surge in sales.
        • Scott Marzahl
          Whats the advantage of the BB fuel line
          What is the advantage for us not in the know? Sure after I replaced mine with another SB line
          • Michael H.
            • January 29, 2008
            • 7477
            Re: Whats the advantage of the BB fuel line
            Scott,
            Actuall, Wayne and I were, ah, just.... making reference to the possibility that a small block car could be more easily turned into a big block car with the addition of the unique big block fuel line. Not that this would ever occur, but if it were to happen, it would be one less item that would require attention.
            • Scott Marzahl
              Nah, that would Never happen *NM*
              • Jim S.
                • March 1, 1986
                • 1402
                LMAO....good one Wayne!!!!
