1960 oil pan ID - NCRS Discussion Boards
1960 oil pan ID
  • Roy B.
    • February 1, 1975
    • 7044
    1960 oil pan ID
    I put this on to help people doing a 60 needing a correct oil pan.
    It's for the Highlift Cam -late 60 and base used. The thing to note on any oil pan are the "spot welds" That is what gives you information when looking to determine what pan your looking at if installed on the engine.
    I have some prints of some pans if you ask C1's
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1957 & 58 oil pan ID
    This is the oil pan design for all 57 & 58 Corvette base engine. The 57 Air Box engine pan #3746258 would be different design. Again look for the spot welds and drain plug location.
    • Chris H.
      • April 30, 1990
      • 817
      Re: 1960 oil pan ID
      Roy, what is the date on the '60 oil pan drawing and is it the same pan used on a '62?
      thanks, Chris
      • terry leeker
        Roy, is there a difference on the '58, 2x4 , 245HP engine?
        • Roy B.
          • February 1, 1975
          • 7044
          Re: 1957 & 58 oil pan ID Terry NO in my print *NM*
          • Roy B.
            • February 1, 1975
            • 7044
            Re: 1960 oil pan ID "chris"
            I took this page out of my book and don't know right now were the prints are. Sorry
