5 Port Washer Pump - NCRS Discussion Boards
5 Port Washer Pump
  • Harold #43147
    5 Port Washer Pump
    I have seen two types on 5 port pumps. One had Barrel loop plugs and the other one has two spade type connection. The only thing I can figure out is the first one is for early 70 that had the full Ignition Shield because the 2 Spade connection would not clear the full ignition shield later models had the top shield only. Is there a rebulid kit for this pump. It took me a bout 6 months to find one at a decent price.
    Thanks Harold
  • Scott Sims
    Re: 5 Port Washer Pump
    Harold, there is (or was) an NOS rebuild kit. I have two kits I bought three years ago off eBay. The "kit" only has the complete white plastic housing unit. There is a guy that shows up on eBay quite frequently that rebuilds those 5 ports. He sells the 5 port pumps/motors for around $350.
    • Dennis D.
      • March 1, 2000
      • 1071
      Assuming your reffering to the electric connections. I believe mine has both. The 2 round connectors on either side of the front plastic cover. The spade connector is from a rubber plug in the round motor housing. Just pulled my engine going to check it out. My cars a 6/16 build.
      • Harold #43147
        Washer pump
        2 different style pump plugs round on 2 sides of plastic cover and second type had straight twin spade type connection. Mine is 5/12 Build Date I think its 12 I know its around there.
        Thanks for reply
        Harold
