Trim Codes - NCRS Discussion Boards
Trim Codes
  • Christopher J. Bunsey
    Trim Codes
    Can anyone tell me what hthe B30 means on my trim code?
    My trim tag appears as follows:
    Cheverolet B30
    TRIM 712 37L PAINT
    Thanks!
  • Dick W.
    • 10483
    Re: Trim Codes
    Christopher without knowing the year model to give you actual month of production, B refers to the 2nd month of production. 30 is the 30th day of the month.
    Dick Whittington
      Re: Trim Codes
      Hi Don,
      It is a 76 Corvette....Thanks for your help
        Re: Trim Codes
        For a '76, B30 means the body build was completed on September 30th, 1975; came off the line a day or two later.
        • rick spears
          Re: Trim Codes
          i believe that B30 stands for Feb 30th.....what is the build date of your car?? my 73 (i think) has a C30 for march, and it is a march car..rick
            Re: Trim Codes
            The letter prefix on the build date code refers to the sequential month of production beginning with the first production month of the model year (usually August, with some exceptions), not the first month of the calendar year. For '76, "B" is September. If your '73 code is "C", that was October, 1972; March for a '73 would be "H", for March '73. No such date as February 30th.
            • rick spears
              Re: Trim Codes
              i believe you are absolutely correct. as i am not home right now, i was thinking my car had a C, but now that you mention it, i does have H30 on trim tag. of course many of the other components have a C (like the flywheel)
              it sure makes it confusing sometimes trying to determine whether it is a calendar date or production date code......rick
