1962 Heater switch - NCRS Discussion Boards
1962 Heater switch
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    1962 Heater switch
    I need some electrical advice. My heater fan operates at high speed on both settings of the switch. I assume I need to replace the resistor on the switch?? Does anyone have the values for the resistor I need ? Any other thoughts are appreciated.
    John
  • Ed Jennings
    Re: 1962 Heater switch
    John, somewhere I have seen a value of 50 watts for this resistor. I have no idea whether this is an accurate number or someone's guess. It might be a place to start.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12740
      See menu option Fan Speed Switch and Defroster Knob on included link!
      Fresh Air & Heating
      Rob.
      NCRS Software Developer
      • John T.
        • January 1, 1983
        • 292
        Re: 1962 Heater switch solution
        Rob
        That has got to be one of the most complete answers ever posted.
        Thank you very much.
        John
        • Roy B.
          • February 1, 1975
          • 7044
          The resister reduces the voltage , slowing the motor , so your's must be burned out. Many early GM cars used the same switch and cable. Most repro's comes from cars.TO tell if a repro was installed in your Corvette most have four connections ,Corvette has two ,if you pull the knob out tightly the motor will run ,but the original will not.
          You can remove the back and cable from the repro , from each unit and switch them if your cable is broken or bad on the original one.
