1965 VIN NUMBERS - NCRS Discussion Boards
1965 VIN NUMBERS
  • Marc N.
    • August 31, 1998
    • 97
    1965 VIN NUMBERS
    Please advise the locations of the vin #s on a 1965 corvette..thanks
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 1965 VIN NUMBERS
    Marc, you will find the vin on the metal plate below the glove box; on the vertical flange at the rear of the of the tranny; on the engine pad; and on the frame. However, the VIN on the frame is not visible with the body on.
    • William C.
      • May 31, 1975
      • 6037
      under the glove box on the front of the brace, on the frame at the rear edge of the drivers door, on the fram on the top of the kickup area, drivers side, in a short forn, on the engine pad and the same on the transmission.
      Bill Clupper #618
