lug wrench - NCRS Discussion Boards
lug wrench
  • Jon S.
    • November 1, 1992
    • 202
    lug wrench
    I'm not sure my 62 has the correct lug wrench. The JM says it should be about 1 inch shorter than the recessed area. Mine has the tag at the thin end and no "o" visible on the head itself. It may have been lost when refinished by the prior owner if it were faint. What measurement should the log straight side be? Can anyone take a quick measurement for me? Thanks in advance! Jon
  • Ted S.
    • January 1, 1998
    • 747
    Re: lug wrench
    I have one from a '60 I used to have. I'm pretty sure it's original since it had the jack, lug wrench, and jack handle. It does have the "o" on it also. What do you mean by "the tag at the thin end"? The one I have is 17 3/8" tip to the beginning of the bend and overall length is 20 5/8" (that's setting the lug end against something flat and measuring from the tip to the flat). I can send pics if that helps. Ted
    • Jon S.
      • November 1, 1992
      • 202
      Re: lug wrench
      Sorry! I didn't catch the n while typing. It should say tang.Guess it was put on the thin end to aid hub cap removal. I suspect mine is not original since the original jack has been replaced with the repro. Thanks! Jon
      • Roy B.
        • February 1, 1975
        • 7044
        Re: lug wrench 61-62 *NM*
        • Jon S.
          • November 1, 1992
          • 202
          Thanks Roy! My lug wrench is a little larger than the specs in your picture. Again, I susspected that it wasn't correct. Buy, it functions well and fits the trunk depression. Thanks Roy! Jon
