Rebuilding Headlight Motors - NCRS Discussion Boards
  • Scott Marzahl
    Has any one ever tried rewinding their headlight motors or know where to get a useable body. I cleaned up one motor and swapped the gear 180 degrees and it runs great. The other motor runs very slow and gets noticeably warm. I am assuming that the winding must be shorted out. Does anyone know what the proper ohm meter readings are to check these motors or a possible repair procedure.
    Scott
  • Alan Drake
    Re: Rebuilding Headlight Motors
    Have had excellent luck refreshing the C2 motors, assume that's what you have. The ohm reading of the armature is close to a short - expect .005 ohms. Assure the armature end that contact the brush is clean (open slots) and smooth. Can put in a drill press and lightly sand the area. Do not use heavy lub if in northern part of country. Be very carful when removing the armature from the casing since the casing contains a brass bushing in the rear that sometimes comes out - then you have real problems. Best information I found was a simple blow up view in the 53-72 Parts Catalog (may be in may others also), however I have never looked into any GM info for rebuilding. If armature is bad, try a starter rebuilding shop they do very similar work. Good luck.
    • Scott Marzahl
      If armature is good, but field windings are bad
      What do you do in that case Alan?
      • Donald O.
        • May 31, 1990
        • 1591
        Re: If armature is good, but field windings are ba
        Send the copmplete motor for a total restoratio to:
        Restoration Service
        Steve Hackel
        15000 S. Knox Ave.
        Midlothian, IL 60445
        708-687-4183
        I have not found anyone better. Haven't had to look either.
        Just my $.02
        Don
