name of '69 part - NCRS Discussion Boards
name of '69 part
  • Marc R.
    • April 1, 2004
    • 288
    name of '69 part
    Just replaced my '69 SB w/AC heater hoses. In the small hose was a black plastic valve with a vacuum input that I thought was a heater control valve. I doubt it is original; it has a made in Mexico sticker still attached. It had been in contact with heat and had melted to where I doubt it will work. I was looking for a correct replacement, but I can't find a 'heater control valve' for a '69 listed anywhere. All help appreciated and thanks.
  • Dick W.
    • 10483
    Re: name of '69 part
    Marc the valve that you are talking about is a vacuum controled heater water cut off used on 69-71 cars with Air Conditioning. Originally it was a metal valve. It is still available from some vendors. I believe that the valve they are selling is the 79-81 style which will function correctly but I cannot tell you about the configeration, whether it is close or totally different
    Dick Whittington
      The later era vacuum controlled hot water cutoff valve is pretty darn close to factory original in configuration + being located in the 'dark' bowels of the RH splash panel area, it's pretty hard to get a close look during judging....
      But, these service replacements are generally gold dichomate finished while the earlier, factory original, cutoff valves were simply silver cad/zinc finished. You can find the real McCoy cutoff valves at your local scrap yard by looking for an A/C equipped Chevy station wagon of the era whose front clip has been removed.
      Typically, it's a simple job of cleaning up the donor cutoff valve and taking it for a 'bath' in your home plating tank. Then, suck on the vac nipple and verify the valve opens and closes properly!!!
