1962 Powerglide - NCRS Discussion Boards
1962 Powerglide
  • ray anthony
    1962 Powerglide
    Other than the normal checks: all aluminun except for bottom pan, serial number, date code, safety switch, filler tube and stick, Is there any thing I should be looking for such as a secondary component or other numbers. Also how critical is the transmission to Top Flight judging.
  • Dave S.
    • August 31, 1992
    • 2926
    Re: 1962 Powerglide
    Ray,
    What year car. ????
    • Dave S.
      • August 31, 1992
      • 2926
      Sorry- Should have read the heading *NM*
      • Bob R.
        • June 30, 2002
        • 1595
        Re: Sorry- Should have read the heading
        I'm not sure about 62 but 63 powerglide is a one year only corvette only part. The unit used in other chevrolets is different. For one thing the tail shaft is a different legnth. I would think the 62 is different then the unit used in the Impala. I know the 300hp trans for the corvette has more clutch plates then the regular chevy unit. I don't know if the physical size is the same or not for 62.
        • John S.
          • July 31, 1990
          • 292
          Re: 1962 Powerglide
          The 62 had a 11 1/4 tail stock with 3 boses for the shifter. 63 and 4 had 5 boses on the tail stock but ony 3 were used for the shifter. They both had coarse spline on the shaft. The 62 shift lever was different than the 63 and 4 but I had a real early 63 that had the same shift lever as a 62 did. The 11 1/4 tail stock started appearing in the 1965 pass. cars. No cooling holes were in the case of a real 62 powerglide. john
