56 hard top???????????? - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    What do you think of my 56 top???
  • Ed Jennings
    Re: 56 hard top????????????
    Very neat. Looks like it is pretty weathertight.
    • Ed Jennings
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        For $7K it should be pretty tight... *NM*
        • Dennis C.
          • January 1, 1984
          • 2409
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12725
            Hi all,
            I thought you had to put them in your cilinders to reduce your ci... (Just kidding).
            greetings,
            Rob.
            Rob.
            NCRS Software Developer
            • Rob M.
              NCRS IT Developer
              • January 1, 2004
              • 12725
              Hi all,
              greetings,
              Rob.
              Rob.
              • Dale S.
                • November 12, 2007
                • 1224
                not the thing for my bald head. dale
                • Dale S.
                  • November 12, 2007
                  • 1224
                  • Dennis C.
                    • January 1, 1984
                    • 2409
                    Appears soft top latches required... *NM*
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Re: Appears soft top latches required...NO *NM*
                      • Dennis C.
                        • January 1, 1984
                        • 2409
                        Oh, Roy, Well that "NO" certainly explains everything in detail I needed or wanted to know about the rear mounting of your hot house for scalp hair regrowth. Thanks, Dennis
                        • Verle R.
                          • March 1, 1989
                          • 1163
                          Roy,
                          How does the top fasten down?
                          Thank you,
                          Verle
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            OK Dennis the meness
                            At the sides behind the door and between the soft top lid a curved strap hold the side in and down ,
                            The rear is a small retainer that is Center of the soft top lid that hold the top down . It don't use the soft top latches or hard top. ( but would use the hard top center screw if one wonted instead of the clamp) if the vett has or had a hard top.
                            And No it wont burn what little brains you have left because it's UV protected Like your sun glasses.
                            • Gerard F.
                              • June 30, 2004
                              • 3805
                              Ever steam up the windows in that puppy?
                              It seems to be parked in front of the right sign.
                              Just kidding Roy, it looks real nice.
                              Jerry Fuccillo
                              #42179
                              Jerry Fuccillo
