60 park brake flange on firewall - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    The AIM seems to show the flange on the inside of the firewall. Mine sure looks like it was on the engine side. Inside?
    Larry
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 60 park brake flange on firewall
    A better description would aid a better reply. What are you calling the flange?Everything is inserted thru the firewall from the interior side. The washer and nut and clip are inserted from the engine side.
    • Wayne P.
      • August 31, 1975
      • 1025
      • Larry P.
        • June 30, 1999
        • 481
        The flange is what they call it in the AIM. It threads onto the bottom of the parking brake shaft and is then attached to the firewall via a bolt, washer and lock washer. What is the "clip" you refer to?
        • Larry P.
          • June 30, 1999
          • 481
          • Mike E.
            • February 28, 1975
            • 5138
            Larry--
            My experience is that it goes on the passenger compartment side. That's what keeps it from being pulled through when the additional hardware is attached on the engine side.
            • Mike E.
              • February 28, 1975
              • 5138
              Larry--
