C2 Vent Glass Insertion - NCRS Discussion Boards
  • Gordon Peterson #4961
    Hi all -
    This afternoon, I started to insert the vent window glass into the frame on my '63. The thought of pounding on priceless (to me) glass with a mallet while juggling the fragile frame and trying to guide the rubber seal was daunting.
    So I took a piece of scrap 3/4" ply, traced the frame onto it, and cut a template. Check out the picture - pretty straightforward. I left extra room around the post. There is also a small notch adjacent to the frame hinge to avoid breaking that off. And the "push bar" has a groove for the glass to keep the whole affair from popping up off the WorkMate as I squeezed it home.
    I used detergent on the rubber seal, and it was completely seated in less than a minute.
    Pete
  • Wayne K.
    • December 1, 1999
    • 1030
    Great idea, thanks for sharing. *NM*
    • Wayne K.
      • December 1, 1999
      • 1030
      • Mike M.
        • May 31, 1974
        • 8385
        Re: C2 Vent Glass Insertion
        liquid detergent analogous to KY jelly. sure makes it smoother going. mike
        • Mike M.
          • May 31, 1974
          • 8385
          • James W.
            • December 1, 1990
            • 2655
            Gordon,
            You should submit that to the Restorer Magazine as a tech article, excellent info.
            James West
            • James W.
              • December 1, 1990
              • 2655
              Gordon,
              James West
              • Scott Butville
                That's basically how GM did it. The only difference was that the glass was fed from a magazine and the tape was fed off a roll. The tape was lubed with soapy water as it was fed.
                • Scott Butville
                    • 15601
                    Gordon,
                    Please send your photo (in as high a resolution as you can) to reatorereditor AT AOL.com AT=@. I can lift the text, but not the photo.
                    Terry McManmon, Editor
                    The Corvette Restorer
                      • 15601
                      Gordon,
