67 Small block oil pan - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    Would someone please post a picture of a small block oil pan showing the area around the rear drain plug? I believe mine is damaged,but could be straightened if I knew what it was supposed to look like.
    Thank you,
    Re: 67 Small block oil pan
    Here's a '67 327/300:
      • Harry Sadlock
        Good day, would anyone have a picture of a 63 5qt. pan. 250/300 hp.
        Harry
        • Harry Sadlock
          Harry
            • 43207
            Harry-----
            It's exactly the same as the above, if what you're interested in is the drain configuration. Otherwise, it's exactly the same as any 63-74 Corvette "5 quart" pan.
              • 43207
              Harry-----
                • 43207
                John-----
                It looks like yours got a little "bumped" in this area, too. You could easily "reconfigure" it the next time you have the pan off, though.
                  • 43207
                  John-----
                  • Harry Sadlock
                    Joe, I have the same bump/dent in my 63. I thought I was seeing things, that's why I asked for a 63 picture (unmolested pan) just to make sure I wasn't going nuts.
                    Harry
                    • Harry Sadlock
                      Harry
                      • Charles M.
                        • March 1, 2002
                        • 155
                        Here is what I have for 5 and 6qt pans - 1964 327cid.
                        Chuck
                        • Charles M.
                          • March 1, 2002
                          • 155
                          Chuck
                          • Harry Sadlock
                            Chuck, Thanks
                            Harry
                            • Harry Sadlock
                              Chuck, Thanks
                              Harry
