C1 neg battery strap - NCRS Discussion Boards
  • Pat #25912
    Can someone tell me how long the negetive battery strap/cable should be for a '59? Thanks. Pat
  • Dave Suesz
    • Dave Suesz
      • Pat #25912
        If you have it out
        it would be a big help. I found a woven cable attached to this old 283 that has been kicking around here and it is 13-3/4" between the centers of the terminal holes. My '59 is in pieces and I don't have an old cable to compare it to. If it is the right size I will spend some time cleaning it up. Thanks Dave for the offer. Pat G.
        • Pat #25912
          If you have it out
          • Brad K.
            • August 31, 1990
            • 414
            Re: If you have it out
            The one I purchased from Eagle Products (part # EPBC-5561)for my '59 is 17" long (hole center-to-center) The lead clamp has a raised "N" about 1/4" high on the surface. The braiding is 1/2" wide. (as per the judging manual)
            • Brad K.
              • August 31, 1990
              • 414
              • Pat #25912
                Thanks. I will have to check out Eagle Prods. *NM*
                • Pat #25912
                  • Justin B.
                    • March 1, 1996
                    • 478
                    Re: C1 neg battery strap
                    Pat, I have my original off of my 58'. From what point do you want me to measure from? It isn't in perfect shape but is decent.
                    • Justin B.
                      • March 1, 1996
                      • 478
                      • Pat #25912
                        Justin, the measurement between the center of the battery post clamp and the hole in the terminal at the other end. The cable I have is 13-3/4" wich seems a little short. Brad's is 17". Thank you. Pat G.
                        • Pat #25912
                          • Kevin Riel
                            Along these lines, where should it attach? The strap on my '59 was attached to the rear exhaust manifold bolt. Is this correct?
                            Kevin Riel
                            • Kevin Riel
                              Kevin Riel
