Best practice for working pot metal headlights - NCRS Discussion Boards
  • Scott Marzahl
    Say, is there a special method to working with pot metal. One of the headlight buckets has a little wave about 1/16" high and 1 inch long right in the center along the front edge. Curious if it should be cold worked or heated in an oven to stress relieve it first or anything like that.
    Re: Best practice for working pot metal headlights
    Should be no problem with gentle, light sanding to take down a high spot.... But, don't attempt to bend/twist a pot metal part!
      • Chuck S.
        • April 1, 1992
        • 4668
        10-4...DO NOT ATTEMPT TO BEND!
        Probability of cracking is virtually 100 percent. Take down slight high spots with fine file, sandpaper...apply body filler to the low spots, and stick it with a fork, cuz it's done. Be happy and don't fret...it'll be more, er...perfect than when it left the factory.
        • Chuck S.
          • April 1, 1992
          • 4668
          • Scott Marzahl
            Re: 10-4...DO NOT ATTEMPT TO BEND!
            Thanks for the tips, I thought by perhaps heating it for a few hours at 350 degrees or so would stress relieve it enough to prevent it from cracking when attempting to work that little ripple out. Guess I better skip that idea for now.
            Thanks again.
            • Scott Marzahl
              Thanks again.
              • Chuck S.
                • April 1, 1992
                • 4668
                Take it from Mr. "It's Only A Little Bit, It'll Be Fine"...getting pot metal repaired can be very expensive. After that experience, I concluded that pot metal has zero malleability.
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  • Mike Cobine
                    ROFL. Pot metal is like cast iron or cast aluminum, it don't bend. Steel and non-casted aluminum bend, pot metal doesn't.
                    I have seen MANY headlight buckets that are cracked at swap meets. They got that way either by impact (didn't bend) or by attempted repair (didn't bend then, either).
                    • Mike Cobine
                      • Mike Cobine
                        Steel and non-casted aluminum ==> Steel and non-cast aluminum.
                        • Mike Cobine
                          • Bryan M.
                            • April 1, 1999
                            • 386
                            I found that out after trying to put a little more bow into my 68's wiper grill.
                            Snap!
                            • Bryan M.
                              • April 1, 1999
                              • 386
                              Snap!
