1965/1966 big block spark plug heat shields - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 1965/1966 big block spark plug heat shields
    Joe I guess you are talking about the back side of the slotted section? at a glance it looks square ,but the squared off corner has a slight radius. The silver very well could have been zinc .
    • Bill W.
      • March 1, 1980
      • 2000
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Scan of 1966 big block spark plug heat shields *NM*
        • Michael H.
          • January 29, 2008
          • 7477
          #19
            • 43219
            #20
            Re: Scan of 1966 big block spark plug heat shields
            Michael------
            This is the configuration with the "squared-off" end. I was referring to the end of the "cut-out" which is adjacent to the bracket. On the 3868828 this surface is supposed to have a modest radius to it. On the 3871266 it's supposed to be "squared off" (like this one). Both shields have the radiused corners at the rear of the "cut-out".
            How long is this shield overall? If it's 2-1/2", then it's configured just like a 3871266 except for length. If it's 3", then it's configured exactly the way a 3871266 is supposed to be.
              • 43219
              #21
              Michael------
              • Louis F.
                • September 30, 1991
                • 132
                #22
                Mike, Joe, and Bill. How are the seams configured on your shields? By the way guys thanks for your knowledge and your response. Lou
                • Louis F.
                  • 132
                  #23
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    Ok, thanks Joe, I was confused. So, this then would be the correct design for most 65-66 applications? I assumed it would be the 2nd design because it was from a 66.
                    It's OL is just about exactly 3".
                    Do you have the print for these?
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      #25
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        #26
                        Scan of 1966 shields front
                        Sorry about the quality. I'll get a better pic later.
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          #27
                            • 43219
                            #28
                            Michael----
                            Then what you have is the GM 3871266 exactly as it's supposed to look. This would be the "2nd design" assuming that the "1st design" was the GM #3868828 and that that piece was ever actually manufactured and used.
                            I do have the print, but I don't know how to post it. No matter, though, as I've just discovered the print for BOTH shields also happens to be in Noland Adams' book on page 285.
                              • 43219
                              #29
                              Michael----
                              • Michael H.
                                • January 29, 2008
                                • 7477
                                #30
                                Ok, my 3871266 has the hole but has the radius corner. That doesn't agree with the print.
